Is it possible for an EQM-35 Pro to carry a Skywatcher 150PDS (4,9Kg) and a DSLR?
6 replies321 views
AstroTimZ avatar
I recently started to look into goto mounts and I was wondering if you can image with the EQM-35 Pro and the 150PDS.
dkamen avatar
You would be close to 6kg with the DSLR, a guiding scope,  a guding camera and the corrector. It is possible but not ideal. I have been using mine with the same guiding gear (ZWO 40/120 + 120MM) and three imaging scopes:
- TS 60/360, total weight 2.3kg with DSLR, length a little less than 40cm.
- Vixen VMC110L, total weight about 2.3kg with a small astrocam, length a little more than 30 cm.
- ZSII73, total weight about 4kg with DSLR and flattener, length about 50 cm.
So with the first two performance is outstanding. 10 minute subs are not a problem, guiding error is usually below 1" RMS or maybe 1.3 if seeing is bad. I calibrate once and it holds it for weeks so long as I image within the same quadrant of the sky or so.
With the ZS73II things are more unstable. Guiding error is between 1.5 and 2.0 RMS (usually closer to 1.5) but more importantly every 15 minutes on average it throws a fit in DEC; error goes > 5" and it takes PHD a couple of minutes to fix it. When I say "on average" I am not implying it is periodic. Sometimes it goes 1 hour without issues, sometimes 5 minutes. Occasionally (not too frequently though) PHD will bail out, complaining that its attempts to correct DEC have no result. But RA is less stable too. I have to recalibrate very frequently because I've found it helps. Overall, it is functional and good enough for me. Definitely works great if I stay at 2 minute subs: statistically 90% will be keepers. But the point is: compared to how perfectly it performs with the lighter/shorter gear… it's like a different mount.
Extrapolating from my experience with the ZenithStar, I expect it to be quite problematic with the 150PDS. It would be operating dangerously close to its capacity or even exceed it. Do not forget, the mount is able to hold 11kg but that's for visual. For imaging capacity is approximately 50% i.e. 5.5kg, let's err on the side of adventure and say 6. So you have 4.9 for the scope alone, maybe 0.5kg for the DSLR, another 0.5kg for guding gear and I don't know how much for coma correctors, adapters and whatnot. And the 150PDS is also much longer than a ZSII meaning torque is much more pronounced, especially if there is wind.
In conclusion, it is probably doable but you would get to throw away many subs and spend too much time being frustrated in every session. This mount excels at compact/lightweight setups. Not a 150mm Newt with a DSLR.
Dimitris
AstroTimZ avatar
I do not recommend using that setup for AP on that mount. I own the mount and with a lot of tuning it is barely capable of guiding at 35 degrees above the southern horizon with a Zenithstar 73, Cooled CMOS, Filter drawer, Guide Scope/Cam Setup. This mount has a lot of loose adjustable ends that will move under pressure over time. So you will be tuning it every now and then with that setup which will be frustrating at best.
Clear Skies,
Allan
Thanks for the response,
On many forums an HEQ5 is recommended for AP, do you think the 150PDS would work on an HEQ5? (with camera, adapters, etc.)
north.stargazer avatar
I also own this mount and I have to agree with the others. It's not ideal for an OTA over 3-4kg plus accessories if your primary focus is AP.
It's really a lightweight mount on a solid tripod and it works great for me with an 80mm refractor, but that would be the most I would put on it.
The HEQ5 sits in between the EQM35 and the EQ6R in terms of payload capacity as well as mount weight. It should easily manage the 150PDS.
Good luck!
Well Written Helpful Respectful Concise Supportive
Taddeuccis avatar
I got a EQM35 pro and i use a 100mm quadruplet (6.3kg) and It works great. I don't use the autoguide, and i manage to get 60s exposure with perfect stars.  The only problem i have is periodic error, bit It is fine, the frames are good even with some periodic error. I'm sure the 150 will work great!!! Good luck and CS
Concise
What would you recommend as an Astrophotography starter kit?
My wife bought me a Skywatcher 200PDS on an HEQ5 Pro mount a few years back as a way for me to get into astrophotography. In hindsight, I would actually recommend: * 150PDS with coma corrector * EQ6R Pro mount Why? * The 150PDS is a great balance bet...
Author has similar Skywatcher equipment; discusses astrophotography setup experiences.
Apr 27, 2022
how improve my equipment
Hi, actually this is my equipment: - skywatcher EQM35 PRO - zwo 533 MC pro - sigma 150-600mm - optolong L-extreme 2" - optolong L-Pro 2" - asiair plus - zwo 30F4 and 120mc With these stuff I can get 300 seconds without star trails so I beli...
Author uses EQM-35 Pro mount; discusses imaging with similar equipment.
Aug 7, 2022
Goto mount recommendations
Hi everyone, I've been using a Skywatcher alt az goto mount that I think is pretty much designed for visual astronomy. It was all I could afford when I bought it a few years ago and got the job done (exposure times of ~30s). It's tracking has...
Author asking about goto mounts; directly addresses mount recommendations.
Jun 26, 2022
Coma or collimation issue? (SkyWatcher 150PDS)
Hello I'm relatively new to the hobby, started last year with a basic reflector on a Go-To mount. I'd like to get some advice regarding poor quality of my shots. My equipment: SkyWatcher Explorer 150PDS SkyWatcher EQM-35 Pro mount Nikon D7200...
Author mentions 150PDS telescope; discusses imaging with this specific scope.
Dec 8, 2022
Sky-Watcher EQM-35 Pro Not slewing
Hello this is my first post here and I'm hoping you folks can help. If this forum is not for equipment discussions I completely understand and please delete it. I bought my EQM-35 Pro brand new April of 21. I used it with no issues several times....
Author has EQM-35 Pro mount; discusses technical issues with this mount.
Oct 2, 2022
