Using a OSC with LRGBSHO filters
5 replies295 views
Brian Meyerberg avatar
I’m new here and sorry if this was covered before but I couldn’t find it with a search.
I love imaging with my monochrome ASI1600 and separate LRGB SHO filters on my 80mm triplet refractor. I’ve also been using a ZWO asi2600 color camera on my 127mm triplet refractor. My question is can I use separate LRGB SHO filters with the ASI2600 color camera and process everything just like it’s a monochrome camera? I probably should have waited for the monochrome 2600. Should I buy the 2600 mono when it comes out and sell the asi2600mc pro (and sell the 2”Triad Quadband filter too). Opinions welcome.
Clearer Skies are Coming!
Nadir Astro avatar
Sure you can, technically. But it's a waste of imaging time under precious clear skies since you'll be getting only 1/4 to 1/2 of signal depending on the color. OSC cameras are already less effective than mono when it comes to LRGB imaging, and you want to limit it even further.
As for 2600 mono when it comes out, I would sell 1600MM and upgrade to 2600MM since it has no amp glow, is a bit larger in sensor size, produce less noise, more full well, etc.
Helpful Insightful Concise
That make sense, and my 36mm filters will still be compatible with the 2600, thank you.
Clear Skies!
Tareq Abdulla avatar
I wish to have a color camera so i can shoot RGB without filters, and i leave the SHO for mono only.
Bob Lockwood avatar
Brian Meyerberg:
I beleive the 2600 needs 2" filters. It has a 43.2mm diagonal chip.
It’s 28.3 mm
Preprocessing Question!!
Two quick questions. When Im loading my lights into the batch preprocessing, its separating my frames into 2 groupings, Filter 1 and binning 1x1, but as far as I can tell the subs are all the exact same filter, binning, etc. The headers of all the fi...
Discusses filter types and configurations relevant to preprocessing grouping issues.
Mar 10, 2019
Toup Tek monochrome with IMX571 sensor - Pros? Cons?
I'm looking at potentially replacing my QSI CCD camera with something, shall we say…less…1992. Okay, so maybe it's not that out of date, but….. Anyway, I've been looking at everything from ZWO ASI294mm and ASI533 to the ...
Discusses monochrome camera alternatives relevant to author's consideration.
Nov 12, 2022
ASI1600MM Pro: impossible to get good flats?
Hello everybody! I'm creating this topic here as the thread on Cloudy Nights is not getting much attetion. I'm sure some of the more experienced astrophotographers might know the fix to this issue, but until now, no one could find something s...
Addresses monochrome camera (ASI1600MM) flat fielding and processing techniques.
Sep 16, 2022
Sell ​​Atik 383l+ with ZWO 8x31mm filter wheel with Astrodon LRGB HSO 31mm filter
Good Morning, since I would like to switch to a camera with a larger sensor, I am offering my current camera setup for sale. Consisting of an Atik 383l+ with an 8x31mm filter wheel from ZWO and a complete 31mm unmounted filter set (LRGB HSO) from Ast...
Covers LRGB/HSO filter setup with monochrome camera workflow.
Jul 13, 2022
