Lens Flare Artifacts in Narrowband Images
6 replies194 views
Chase Davidson avatar
Hi everyone,
I've noticed a few of my narrowband images have recently had some horrible lens flare when capturing at 300s (at least that's what I think it is). I thought it was a flats issue but after much experimentation, I've found flats do not fix the flare. I'm using a 2600mm on a Redcat 51, maybe it's overexposing? The individual subs do not show any of these artifacts, that's why I thought it may be a flat issue. Is there anything post processing that can fix this or should I retake at lower exposure time? See shots for examples below.
Chase
Flame Nebula Sulfur data light flareOrion Oxygen data (Orion Nebula has flare)
Rosetta Nebula Hydrogen Data light flare
It isn't a lens flare, That's for sure. Read-out issues most likely.
Nlawrie94 avatar
I had these occur when calibrating files in pixinsight with WBPP. Using the Linear defects correction caused them to occur on my calibrated light files. They were not present on my RAW image files. A reprocess without "LDC" solved my issue.
You are a hero, I’ll run wbpp now and let you know.
That did the trick, thanks so much!
Nlawrie94 avatar
Chase Davidson:
Awesome!
Mauro Sturaro avatar
From what I understand, "linear defect correction" is meant for readout problems typical of CCD sensors; it should not be useful for CMOS sensors.
Dark vertical streaks in stacked image
I've been struggling with trying to understand the source of these streaks I see in some recent stacked images. I'm hoping someone here can offer an idea as to what the source is. I'm hoping it's not the camera itself. My set up is a ...
Stacking artifacts similar to lens flare issue author is experiencing.
Aug 21, 2025
Over correcting flats with fix
Howdy all. I've been rather bummed with the quality of my images for the last 9 months. I have data collected for two projects that I never finished due to the poor quality. Recently I discovered that my flats were over correcting my LRGB images ...
Discusses flat correction problems relevant to author's flat troubleshooting.
Aug 17, 2025
Flats issue with ZWO6200MM
GDay all. Im currently using an Askar FRA500. I was using a ZWO 2600MM and Antlia filters prior and never saw what Im seeing at the moment. Went mad and purchased a ZWO6200MM, FW and 50mm Antlia filters. I took a 300s dark frame when I put it all tog...
ZWO 2600MM camera flats issue directly matches author's equipment.
Jun 3, 2025
Fixing scattered light issue
Hi all After few days of Ha & Oiii acquisitions I finally checked my result. And of course as always I found an issue on integrated images I have quite nasty scattered light in right top corner. Of course it's on both images so I don't ha...
Scattered light artifacts in stacked images similar to author's flare.
Jun 28, 2025
[RCC] Streaky artifacts in M42 and request for critque
Hi everyone and greetings from Germany! I hope the awesome astrobin community can give me some help I recently processed data from M42 and i noticed two things: The stars at the edge of the picture are not roundThere are streaky artifacts all over th...
Lens flare artifacts with refractor lens similar to author's setup.
Feb 20, 2022
