HA processing experiment , what do you think ?
4 replies404 views
James avatar
Hi all , I was looking for a way to get pure Ha and color stars , so I came up with this after some time , it might be something stupid, but I like the result
I shot LRGB and Ha with a mono camera .
I processed Ha as normal streched,  removed stars and converted to RGB . to that  I added color stars I had  removed from a RGB version  and applied  L  .
 I tweaked the image in curves  then removed stars and reduced them .
here is what I got ,
What do you think , is it any good , is it rubbish, perhaps its a common way of processing , I don't know but i never saw it before
cheers and clear sky  !!
https://astrob.in/94xown/0/
Ashraf AbuSara avatar
I really like the result, but don't follow the process. Can you elaborate more on your on how you converted the monocrhome Ha frame to RGB?
James avatar
Hi , sorry , here I go :
1 Ha mono image , process as normal , remove stars . and convert to RGB, you get an B&W image of Ha
2 add to the B6W RGB Ha the color stars from a normal RGB composition , you get your B6W image with color stars and tainted colour Ha
3 saturate with curves and tweak as you like
4 add Luminance to your image ( I has shot L R G Boo the same image )
5 remove stars , tweak and add stars again
hope that's easier to understand
cheers
James
James avatar
Just was curious to know if anyone else had tried, I was expecting to get a B&W image with color stars I thoughtcould look nice ;-)
Frank Alvaro avatar
James:
Coincidently,  I was trying the same thing yesterday with a boring RGB image of a Sharpless nebula which looks much more interesting as just a  monochrome Ha image. I didn't go very far with it, but maybe I should try again to get the RGB stars combined with it.
[RCC] NGC 7000
I created two versions of this image, one with fewer stars than the other and have otherwise been struggling with narrowband. I got this data from Telescope live and thought it should be a good test of basics so I thought id give it a go and ask you ...
Author discusses narrowband processing and star removal techniques similar to post.
May 27, 2025
[RCC] Galaxy post processing M101
Request you to provide your critique - It is my first attempt to post-process galaxy data. I obtained the data from TAIC workshop. The LRGB subs were already stacked and registered, even cropped to good extent. I proceeded with these steps, providing...
Author seeks critique on LRGB post-processing workflow comparable to source method.
Aug 19, 2025
Should I utilize Sii data for Crescent Nebula? If so, what are some good ways.
Hey guys, Been imaging Crescent Nebula. Originally I started getting Sulfur along with Hydrogen and Oxygen, but looking at the Sulfur, it doesn't look like it's going to add much. I've been trying some custom blends, but none of them look...
Author discusses narrowband data processing with Ha and other filters.
Aug 21, 2025
RGB + H-Alpha Galaxy Star Formation Knots
Hi All, I am asking for your advice. I have recently elaborated an image of NGC2403, having RGB data and H-Alpha plus OIII. I used the NBRGBC process in PixInsight to combine the NarrowBand and RGB data. This is the image https://astrob.in/pqncwq/B/ ...
Discusses HA processing techniques relevant to author's star-formation knot isolation challenge.
Dec 23, 2021
New script for Osc dual band images
Hi all, I just published a new script (for Pixinsight) to convert Osc dual band images in RGB format to a HaOO image. I used the script to process this image https://www.astrobin.com/4zy08q/. If you would like to download it, then you can find it her...
Ha processing from OSC data relevant to author's conversion method.
May 29, 2022
