Hi from light-polluted The Netherlands
4 replies98 views
Sander van der Wal avatar
Hi everybody
I'm a visual observer and telescope builder branching out into astrophotography. As is common nowadays, the lockdown gave me the extra time to start this addition to the hobby. Been dabbling in it for a couple of years, and took the plunge last spring.
I am based in Leiden, which is right in the middle of a very light-polluted part of Holland. My plan for now is to do astrophotography from home only. My view of the sky there is quite good for a city view, about 160 degrees not quite centered on south. Started with a Vixen GP and a WO Zenitstar 61, upgraded to a HEQ5 with a 15 cm Sky-Watcher Newton. I also have a C8 and the plan is to start using that later on. I also have access to the telescopes in Leiden Observatory. The camera is a Canon 1100D, the plan is to upgrade to a monochrome camera with filters at some point in time. I also have a ZWO asi120mc-s for guiding and planetary work.
I'm not fond of processing, as I am behind a computer quite enough already. I am interested in processing techniques that can run unattended. I realize that that won't work for a lot of objects, but with my skies I don't believe I will be shooting these anyway.
Regards
Sander
Fritz avatar
Sander,
welcome to the Astrobin community. I live in Austria, in Vienna, the area is heavily light polluted too.
I have two ways of dealing with light pollution: First and foremost I travel. I do not mind to drive a few kilometers for a darker spot. In many cases I am able to avoid bad weather this way too.
When I am to lazy to drive long at night, I use narrow band filters on a monochrome camera. This is a proven way to deal with light pollution and many people here make amazing pictures out of suburbs, towns or even cities. Then there are light pollution filters. I never used one, but there is tons of information in the net and many useres here use this type of filters.
Best
Fritz
John avatar
hey sander ,Welcome.
Well..try to get as fast as possible to get a mono cam,even second hand is better then that canon.
i live in a dark place,but  the randstad  is to bright for that.  with mono cam you can do always narrowband,ha o3 and S2 will give great results.
Here some great shops,wich will have second hand also.
greetings and good luck..John.
http://www.te-les-koop.nl/
https://www.robtics.nl/nl/8279-occasions
https://www.ganymedes.nl/
https://www.teleskop-express.de/shop/index.php/language/en
Douwe79 avatar
Welcome Sander,
It's not a bad thing to start out with a DSLR, since there are already enough things to learn as a beginner. Whenever you feel you're getting the hang of it, you should consider switching to mono indeed. I recently switched  and have ordered the ZWO 1600 mm pro + 8x1.25 inch filter wheel + lrgb filters from ZWO. Will probably buy the narrowband filters as well when budget allows it.
Clear skies!
Douwe
Well written Respectful Concise Supportive
lucian_nicu avatar
Hello.
I live in a Bortle 5-6 location (according to the light pollution map) but I am surrounded by street lights  (the "best" kind, LED, of course). To give you an idea, the best place for astrophotography that I have is the one located exactly in the shadow of an LED pole, 4 meters away from it.
Like you, for now I use DSLR cameras (a modded Canon and a stock Nikon). The solution I found reasonable at this time was to buy 2 filters: one for light pollution (IDAS LPS D2 - which removes much of the LED light) and one for contrast, a dual / tri narrowband filter (Optolong L-enhance). So far the results are satisfactory for me.
As colleagues said, a mono camera and narrowband filters would be a much better solution, but I proposed a less expensive option that you can apply quickly.
The decision is yours, of course.
Good luck and clear sky!
Well written Helpful Engaging
Hello from Netherlands
From a bortle scale 6 town in the Netherlands (and we call ourselves the City of Light ) greetings and clear skies. Picked up astrophotography again, with a new zwo cam and reflector scope. Learned a lot already learned a lot viewing on this site
Dutch visual observer transitioning to astrophotography like the author.
Apr 19, 2019
Gradient removal in mono data (luminance channel)
Hi, this might be a beginners question for some, but I just changed from a OSC to a mono-CMOS camera and I am wondering how to effectifely remove a light pollution gradient in a greyscal image (e.g. luminance channel). Doing this with OSC data is eas...
Light pollution gradient removal relevant for light-polluted urban location.
Jun 23, 2022
Star Adventurer with Stellarmate/KStars/EKOS/PHD Auto Guiding - Getting Started
Hi All, I just installed Stellarmate on my RPi4 and have got it ready to be plugged into my setup: Star Adventurer 2 Main Camera: Sony A7III Guiding Camera and Scope : ASI120MM Mini (mono) and ZWO Guide Scope Stellarmate OS on RPi4 I am quite confuse...
Star Adventurer setup guide useful for beginner astrophotography equipment.
Jun 30, 2022
Better shaped stars with the Star Adventurer
Hi all, I have just started astro-photography a few month ago and I use now a Canon DSLR/Lens with a Star Adventurer on a good photo tripod without guiding. I am quite happy with the result I get with my 70-200mm L @ 200mm up to 60sec or even 120sec ...
Star Adventurer beginner tips directly applicable to similar setup.
Jan 29, 2022
