Omegon 150/750 eq-3
3 replies69 views
karimahmad2004 avatar
Hello everyone, I have this Newtonian Reflector telescope and I am willing to start taking planetary images and maybe some deep sky objects, what accessories do you suggest I buy? Do you suggest buying a tracking motor?
Kai Linde avatar
Hi!
I used the telescope on a Skywatcher EQ 6 R Pro. I didn't photograph planets but deep sky objects with a Canon EOS 70D. You definitely need an adapted focuser, otherwise you won't find the focus point. You definitely need automatic tracking for deep sky objects.
Carpe Noctem Astronomical Observations avatar
Hi, I believe this Newtonian isnt really made for photography. I remember I tried to use a Canon DSLR and I could not get it to focus. It may be different with a different camera like a tiny planetary or when you use a barlow lens but I never tried that. I ultimately ended up getting a 200/800 Newton which is also not very expensive but designed for photography from the beginning (2-inch focusser, secondary mirror calculated and positioned appropriately and so on).
Kai Linde avatar
Carpe Noctem Astronomical Observations:
What you say is absolutely right. I also only used it as a beginner's test telescope. I had 3D printed a shorter focuser to find the focus but it had a lot of tilt.
Good telescope for a beginner
Hey all! I've been thinking about getting a telescope but I have no clue where to start. I've talked to my friend about what to get and he suggested a Bresser Pollux 150/1400 EQ3 with some additional equipment. I'd like to ask if this is ...
Beginner telescope advice may cover accessories and equipment recommendations.
May 31, 2025
New to astrophotography, and i appreciate your advice on what to buy!
Hello, I moved recently to a village in the north of Morocco, and it's pure dark here; you can see a lot of stars. I was always fascinated by the universe and the sky. I watch a lot of YouTube videos about astrophotography and am currently using an i...
Astrophotography beginner seeking equipment advice for imaging setup.
Nov 9, 2025
I am between scopes to begin with.
Hello, I am intrested in DSO astrophotography for a while now and whant to build my own rig. I am still between 3 scopes wich are the Red-Cat 51, Red-Cat 71 and the Zenithstar 73. As camera i was thinking to get ASI585MC Pro to begin with. What will ...
DSO astrophotography rig building with scope selection and accessories.
Jul 19, 2025
