Station Mode with the ASIAIR Plus
5 replies352 views
Jerry Gerber avatar
I usually leave my ASIAIR Plus in station mode.  What I am unsure of, and no manual explains this, but is it best to connect my Android tablet that controls the ASIAIR Plus to the ASIAIR itself or is it best to connect the tablet to my home Wi-Fi router?   Both work, but will one or the other connection produce a more robust signal?
Jerry
Well written Engaging
Lasse Skov avatar
Hi Jerry
I use station mode exclusively so my phone can be online at the same time. I have never add any issues with it - but I guess it depends of how far the ASIAIR is from your router and how powerful the signal is smile
Jerry Gerber avatar
Lasse Skov:
Hi Jerry
Hi Lasse,
Do you connect the phone directly to the ASIAIR (as it sends wifi like a router) or do you connect the phone directly to your home wi-fi router?  Or, do you do both, depending upon whether the phone is closer to the ASIAIR or closer to the router?
Jerry
Ashraf AbuSara avatar
I always use Station mode unless I am travelling. No reason to use AP mode at all if you can use station mode. As long as your ASIair is capable of communicating with your home network, then you can basically control it from anywhere you have connectivity to your home network.
Lasse Skov avatar
Jerry Gerber:
Lasse Skov:
Hi Jerry
Hi Lasse,
Jerry
Hi Jerry
I always connect to my home WiFi router. The ASIAIR Plus seems to have a somewhat strong antenna as I never have disconnects. And even if I lost connection the ASIAIR will continue running anyway
Jerry Gerber avatar
Lasse Skov:
Jerry Gerber:
Lasse Skov:
Hi Jerry
Hi Lasse,
Jerry
Hi Jerry
OK, Thanks Lasse!  I'll try keeping the Android tablet connected to my home wifi when I image in the backyard..
Well written
ASI Air Pro Connectivity - My solution
I love the ASI Air Pro and, it's functionality is all I need to enjoy this hobby. But like many ASI Air Pro users I've been battling the terrible internet connectivity for about 6 months now. My experience are rich and varied every night. Bar...
Station mode connectivity issues directly match your ASIAIR Plus station mode problems.
Jan 21, 2022
Wired Ethernet problems
Hello, All A little backstory. The only way I can control the ASIAIR Plus (AAP) with my Lenovo tablet is to set my tablet wifi network to the AAP access point network. After AAP bootup I then can go into Station Mode using my home wifi network - afte...
Discusses ASIAIR Plus connectivity issues; directly addresses tablet-to-device connection problems.
Apr 20, 2025
