ASIAIR PLus and ZWO EAF
9 replies480 views
Jerry Gerber avatar
When I am in Autorun taking a series of subs, and I have the ZWO EAF set to refocus every hour, what happens to autorun?  Does the imaging continue while the focusing is being redone, or does imaging stop?  I am not sure as it's happening right now and the screen shows the EAF calculating the new focus point.
Jerry
Well written Engaging
Thomas Groh avatar
Hm, normally it should stop. I never thought about it, because if I start an imaging session, it makes automatically an
autofocus before imaging and not while. Take a look in the logs, there you can find what it does the whole night.
CS Tom
Jerry Gerber avatar
Thomas Groh:
CS Tom
OK, I'll check the logs, thanks.
Tommy Blomqvist avatar
If I remember correctly the refocusing procedure happens between imaging frames with my Pro.
* Usually I don't use interval/time based refocusing but I've tried it. In my case temperature based (and object and/or filter change) makes more sense as my equipment seems quite static if nothing else changes.
Jerry Gerber avatar
Thanks for the tip.  I'm using the EAF for the first time this evening with an Edge HD 8 and was thinking about mirror flop (I don't lock the primary mirror down if I'm using autofocus) so I am focusing every hour.  But I'll have to experiment to see if temperature-based focusing is more efficient.
Well written
GiffS avatar
I also have mine set to temperature not time but I am running a refractor. Exposures pause during the focus routine and resume when done. With an SCT you more than likely will want both if you intend to run unattended overnight. Particularly true if like me right now.  I will see temperatures drop by 20 or 30 degrees overnight. I was out with my C8 and an EAF with hand control last night and without a dew heater running focus was a constant tweak on planetary stuff.  It would eat up a ton of time if autofocus were to run as often as I had to manually adjust focus last night.
Sean Mc avatar
I think it’s a bug. When i go into the app when an autofocus is happening, it looks like an exposure is still completing but it’s not really. The current exposure looks like it continues until the timer stops, but there is nothing to download.
Richard Carande avatar
If you look at the ASIAIR log file, it clearly shows the autofocus procedure takes place between the subs.  The next sub won't happen until guiding settles also.  Here's an example from one of my recent log files:
2023/11/17 21:52:08 Exposure 300.0s image 22#
2023/11/17 21:57:09 Exposure 300.0s image 23#
2023/11/17 22:02:11 Exposure 300.0s image 24#
2023/11/17 22:07:12 [Guide] Dither
2023/11/17 22:07:12 [Guide] Dither Settle
2023/11/17 22:07:50 [Guide] Settle Done
2023/11/17 22:07:50 Start Tracking
2023/11/17 22:07:50 [Guide] Stop Guiding
2023/11/17 22:07:50 [AutoFocus|Begin] Run AF 2 hours later, exposure 3.0s Bin1, temperature 11.2℃
2023/11/17 22:07:50 Find Focus Star
2023/11/17 22:07:58 Find Focus Star: detect and calculate star size 3.2 ,  EAF position 31811
2023/11/17 22:07:58 Find Focus Star: finding appropriate stars star size 3.2
2023/11/17 22:08:13 Find Focus Star: detect and calculate star size 9.5 ,  EAF position 31961
2023/11/17 22:08:13 Calculate V-Curve
2023/11/17 22:08:21 Calculate V-Curve: detect and calculate star size 9.2 ,  EAF position 31961
2023/11/17 22:08:30 Calculate V-Curve: detect and calculate star size 7.4 ,  EAF position 31931
2023/11/17 22:08:39 Calculate V-Curve: detect and calculate star size 5.1 ,  EAF position 31901
2023/11/17 22:08:48 Calculate V-Curve: detect and calculate star size 3.7 ,  EAF position 31871
2023/11/17 22:08:56 Calculate V-Curve: detect and calculate star size 3.4 ,  EAF position 31841
2023/11/17 22:09:05 Calculate V-Curve: detect and calculate star size 3.1 ,  EAF position 31811
2023/11/17 22:09:14 Calculate V-Curve: detect and calculate star size 4.0 ,  EAF position 31781
2023/11/17 22:09:23 Calculate V-Curve: detect and calculate star size 5.5 ,  EAF position 31751
2023/11/17 22:09:32 Calculate V-Curve: detect and calculate star size 7.4 ,  EAF position 31721
2023/11/17 22:09:40 Calculate V-Curve: detect and calculate star size 9.5 ,  EAF position 31691
2023/11/17 22:09:47 Find Focus Point
2023/11/17 22:09:55 Calculate Focus Point: detect and calculate star size 4.4 ,  EAF position 31887
2023/11/17 22:10:04 Calculate Focus Point: detect and calculate star size 3.8 ,  EAF position 31872
2023/11/17 22:10:13 Calculate Focus Point: detect and calculate star size 3.5 ,  EAF position 31857
2023/11/17 22:10:22 Calculate Focus Point: detect and calculate star size 3.3 ,  EAF position 31842
2023/11/17 22:10:30 Calculate Focus Point: detect and calculate star size 3.3 ,  EAF position 31827
2023/11/17 22:10:30 Auto focus succeeded, the focused position is 31827
2023/11/17 22:10:30 [AutoFocus|End] Auto focus succeeded
2023/11/17 22:10:34 [Guide] ReSelect Guide star
2023/11/17 22:10:35 [Guide] Start Guiding
2023/11/17 22:10:36 [Guide] Guide Settle
2023/11/17 22:10:42 [Guide] Settle Done
2023/11/17 22:10:42 Exposure 300.0s image 25#
2023/11/17 22:15:43 Exposure 300.0s image 26#
2023/11/17 22:20:45 Exposure 300.0s image 27#
Dave Rust avatar
I use EAF with ASI in Plan Mode, which is similar…and it stops sub exposure during the routine, resuming after guiding returns the stars to proper location. It also sometimes follows realignment with a dither move if, in fact, the EAF interruption took place right before a dither move was planned.
Don avatar
Dave Rust:
I use EAF with ASI in Plan Mode, which is similar...and it stops sub exposure during the routine, resuming after guiding returns the stars to proper location. It also sometimes follows realignment with a dither move if, in fact, the EAF interruption took place right before a dither move was planned.
That has been my experience also.
ZWO EAF HELP
How would I attach a ZWO EAF to this focuser? I havent seen one attached to this particular focuser and I imagine i would have to jerry rig the set up…
Addresses ZWO EAF integration and operational questions.
Apr 3, 2022
