Ar-Glass or IR-Cut Filter
5 replies422 views
Anderl avatar
Hello fellow Astro-Friends,
do I need an ir-cut filter build into an mono camera used on an refractor as long as I shoot my pictures through rgb/sho filters?
would like to get an imx571 mono but sadly the seller only offers it with an ar-protection glass.
cs and thx
Andi
No. Only with luminance and assuming those filters have no IR leak.
Michael Ring avatar
AR glass is (from my point of view) the better choice because it lets all relevant light in. Yes, you will need an extra UV/IR filter to filter out the unwanted frequencies but for example Antlia recently added an extra IR filter to their R G B L filter set, you would not be able to get meaningful results without AR glass with the new near IR filter.
Also, when you plan to use other filters later you will anyway have to add an extra UV/IR filter with the same thickness as your other filters because the backfocus changes when using filters (0.8mm for filters with 2mm thickness) and only with same backfocus for all filters you will get round stars in the corners for every filter (assuming your filters are parfocal)
Michael
Tyrel Smith avatar
I second what has been said already. Mono cameras don't typically have built-in UV/IR cut filters. It they did it would limit their usefulness to certain demographics that may want to take advantage of their sensitivity in those bands. Instead, a luminance filter is used (typically, but with exceptions) that has the desired UV/IR cut feature. As you hinted, a UV/IR cut filter is not needed in conjunction with RGB or SHO filters, since those filters' bandpass already exclude the UV/IR wavelengths.
A good AR coating on your sensor window (and filters) is valuable to mitigate internal reflection artifacts.
Happy imaging!
Tareq Abdulla avatar
AR glass window
Would you replace the Built in UV/IR cut on a 2600MC with AR glass?
Hello All, I am looking to replace the built in UV/IR cut window on a 2600MC-Pro with AR window and using a better UV/IR cut filter with better cutoffs in the UV and IR (Baader cmos optimized UV/IR cut filter) so i get less UV and IR and better glass...
Discusses UV/IR cut filter replacement options for mono cameras with AR glass.
Sep 18, 2025
UV/IR needed?
I am wondering about the common wisdom of always using a UV/IR cut filter if shooting broadband OSC. I can understand its use with refractors that might not be well corrected at the extremes of a cameras sensitivity range but why do it with a reflect...
Directly addresses UV/IR cut filter necessity when using filters on refractors.
Mar 23, 2025
ngc3718
hallo fellow friends of the night sky, i am looking for some critic and ways to improve my processing. I took the picture with my esprit 120, imx571m, eq6r pro and antlia lrgb filters. it consists out of around 35h of exposure time. - around 300 Lum ...
Shows IMX571 mono camera usage example with refractor telescope setup.
Apr 8, 2025
